Help with plumbing fuel system
Old Mar 22, 2006 | 08:39 PM
Bimmer Tech's Avatar
Default Help with plumbing fuel system
I'm trying to plumb in the 'vette FPR/filter and fuel rail into my Fiero and I can't find what I need to tie it together. The fuel lines for the fiero are 3/8" feed and 5/16" return, both are hard lines with soft lines hose clamped to them. I know I can get AN adapters wth the LS1 quick disconnects for the filter and rail, but how do I connect the AN lines to the Fiero hardlines? Or are there quick disconnect adapters that have splines for a soft line and hose clamps? Any help is greatly appreciated!
Old Mar 22, 2006 | 10:04 PM
67RSCamaroVette's Avatar
AN compression fittings. "You will need special fittings to adapt to the 3/8" feed lines and 5/8" return line. They are available from russell performance products.
You will need (2) 3/8" fittings, part number RUS-639210 or RUS-640850. They're for from the tank to regulator, and the line out to the rails.
You will need (1) 5/8" fitting (part number 640860) for the return to the fuel tank from the regulator."'
i copy pasted it thats why it sounds funny but there you go.
olly
Old Mar 22, 2006 | 10:07 PM
John B's Avatar
Moderator
Of course I could make life easy for you and just sell you a '97-'98 C5 fuel rail with brazed on -5AN return & -6AN supply fittings! PM me if interested.
