Steve68's Camaro.
Just a couple of pics of some work going on,
Installed the engine withe the Speartech Harness, still have to drill a hole and route it inside, not really liking the wiring protection the covering used is open around the ends needs to be cleaned up IMO,
Started mocking up the Alston G Link, Starting prefiting brackets which lead me to finish cutting out the drivers side area and make the frame closeouts,
Passenger side is in good shape needs to be cleaned up some, spray bombed some primer on there a year or two ago,
More to come, Get teh close outs done and install the DSE tubs,
Motor and trans are in but need to sit lower, need to modify the mounts, will be coming along shortly,
Welded the rear end cradle in and the upper mounts on the rear, setting up the lowers today, going to the welder tomorrow, then the chassis shop for shorting and powder coat,
Harness is in, all hooked up,, theres somethings I'm going to change,so I will lay it out on a board and start my mods,
Pics may come later,
Now if I could get a straight answer from someone at Alston about the weld on LCA mounts for the G Link rear-end kit I'd be amazed!
now its time to shorten it up and get it blasted and powder coated,
Have to work on some pictures..........
but there's been some progress,
some random pics,
