VATS bypass help!
Old Mar 26, 2006 | 07:45 PM
lechner80's Avatar
Default VATS bypass help!
Does anyone do a vats bypass for the 04 GTO? Thanks John
Old Mar 26, 2006 | 11:06 PM
dynosmith's Avatar
Check with the group at LT1 Wiring - http://www.lt1350.com/.
I am using an 04 GTO LS1 for my conversion, but I am just going to remove the VATS with EFILive.
Old Mar 26, 2006 | 11:13 PM
Sabre002's Avatar
should be no different then any other LS1
Old Mar 27, 2006 | 04:22 AM
txoutlaw's Avatar
I would find some one with HPT, EFILIVE, ect. to remove it!
Old Mar 27, 2006 | 08:08 AM
lechner80's Avatar
Exclamation Vats Help
[QUOTE=dynosmith]Check with the group at LT1 Wiring - http://www.lt1350.com/.
I am using an 04 GTO LS1 for my conversion, but I am just going to remove the VATS with EFILive.[/QUOTE
Contacted www.lt1350.com they tell me that no one makes one for the GTO. I will eventually have the computer done but for now I just what it to run.
So I'm still looking for Help. Thanks All John
Old Mar 27, 2006 | 10:23 AM
Jones'n's Avatar
That vehicle uses serial data to turn the VATS on and off, you can't just wiire in a bypass module, you have to either reprogram the computer, or get the body control module and everything from the donor car and wire it in.
Easier to reprogram.
Old Mar 29, 2006 | 09:00 AM
lechner80's Avatar
Thumbs up
Thanks Jones'n guess it programing time. John
