?s about T-56 trans.
Old Mar 28, 2006 | 05:36 PM
Stampede4ever's Avatar
Default ?s about T-56 trans.
Does the clutch engage on the t-56?
Thanks.
Old Mar 28, 2006 | 09:38 PM
Teetoe_Jones's Avatar
What?
You need to clarify a bit.
Tyler
Old Mar 28, 2006 | 10:37 PM
Slo_240sx's Avatar
Yes when you let off the clutch pedal.
Old Mar 29, 2006 | 12:00 AM
Wnts2Go10O's Avatar
this should be good, wheres my popcorn :popcorn:
Old Mar 29, 2006 | 02:42 AM
txoutlaw's Avatar
I'll bring the beer!!!! And we'll watch the SHOW!
Old Mar 29, 2006 | 09:07 AM
Scooter70's Avatar
This is an easy one.
Yes. The clutch does engage when you let off the pedal.
Old Mar 29, 2006 | 05:24 PM
How does the clutch engage, by a cable and shift fork, or is it a hydralic?
Thanks.
Old Mar 29, 2006 | 06:49 PM
Flashman's Avatar
On GM vehicles, it is hydraulic.
Old Mar 29, 2006 | 07:00 PM
Thank you, that's what I thought, now, how can adapt this setup to a none hydraulic setup?
Thanks.
Old Mar 29, 2006 | 07:50 PM
67RSCamaroVette's Avatar
Details would help out alot.. What vehicle, what engine... A LT1 T56 uses a cable.. You wouldnt be able to change a ls1 style to non-hydraulic easiliy, it'd require a different throwout setup, a different bellhousing, and all the linkages to make it work.. Its easier to just fit the LS1 hydraulic master to the car with a bracket..
olly
Old Mar 29, 2006 | 08:58 PM
That's just it, I don't have a car yet, but the two I'm thinking of didn't come with manual trans, so I'll have to make a setup. My next question is how does the hydraulic master work? I assume like a master cyclinder. Where could I find pictures?
Thanks.
Old Mar 29, 2006 | 10:15 PM
pwrtrip75's Avatar
The same way a brake system works. Master cylinder and a slave cylinder. The slave would do the same as a wheel cylinder, except inside the bellhousing actuating the pressure plate. If your thinking of putting a T56 in an older vehicle, I'd use the whole setup, bellhousing and Hydraulics. It will bolt right up to an old small block if you wanted and all youd have to do is rig up a pedal and master, then its just a hyd. hose and your done.
Old Mar 29, 2006 | 10:28 PM
LS1Bandit's Avatar
You might want to check out this page:
http://www.geocities.com/thelastcaboose2/Page2.htm
Scroll down to: "More custom modifications"
It has some pretty good photos of how he mocked up connecting the hydraulic cylinder to a standard clutch pedal.
