Need to confirm a wire color on 02 Camaro PCM
Both of my non GM pin outs also say purple, if it is the fuel level input wire it should go to blue connector 230 pin J. Check the color there/trace it/ or check it for continuity. If it goes to C230 pin J mabey that ran out of purple wire and used black?
It is one of the 2 dashboard connectors, they go to the part of the harness that goes into the car. It also has the MIL light wire and serial data OBD II wire on it. I am not sure where it is actually located in the engine compartment though, I never worked on a camaro
