Camaro oil pressure sensor specs
Old Mar 31, 2006 | 08:59 PM
99c5vert's Avatar
Default Camaro oil pressure sensor specs
Does anyone have the sensor specifications (i.e. pressure vs. resistance, or equiv)?
Old Jun 28, 2006 | 05:46 PM
super_kev's Avatar
I'm curious about this as well, as my Helm manual doesn't show anything (unless I'm looking in the wrong place).
Old Jun 29, 2006 | 01:50 PM
bczee's Avatar
Curious, what are you trying to do or build .. I know you should just be able to use the sender of the car you are swapping into or the aftermarket gauge. But if ur doing something different.. keep us posted..
Old Jun 29, 2006 | 07:06 PM
99c5vert's Avatar
Hi, I ended up swapping the sensor for a 'vette unit, then using the A/C pressure sensor input to read the oil pressure.
Old Jun 29, 2006 | 09:45 PM
super_kev's Avatar
I'm just looking for specs so I can see if the LS1 will work with my '85 T/A oil psi gauge. I know people have said it won't, but I'm curious why it won't. That's why I was looking for the ohm readings.
Old Jun 29, 2006 | 09:52 PM
99c5vert's Avatar
sorry, I don't have any
