Lt1 T56 Onto Ls1???
Old Apr 4, 2006 | 10:01 PM
FIREHAWKONNOS's Avatar
Default Lt1 T56 Onto Ls1???
What Tranny Parts I'm I Going To Need To Hook Up My T56 Lt1 Trans To A Ls1 Motor I've Been Looking For A Flywheel But I Cant Find One To Do This Please Any Help Would Be Great I'm Sure Some Of You Guys Have Gone Through This Already Thanks.
Old Apr 4, 2006 | 10:09 PM
67RSCamaroVette's Avatar
It would be much easier to get a LS1 T56 because alot of things are different, Input shaft, bolt pattern, are you using the Lt1 just because you have one laying around?
Last edited by 67RSCamaroVette; Apr 8, 2006 at 03:15 AM. Reason: made a boo-boo. spreading information about the nonexistant LT1 cable clutched T56..
Old Apr 4, 2006 | 10:11 PM
my car is a lt1 car which i'm putting in a ls1 and want to make it as easy as possblie i'm working on a tight buget, my motor is blown so i figured why rebuild a lt1 when i can put in a ls1
Old Apr 6, 2006 | 08:35 AM
72chevy72's Avatar
LS1 + Tight budget = Rebuild LT1...
Old Apr 6, 2006 | 09:13 AM
kossuth's Avatar
Yeah, you need a new bellhousing for the T56, new front plate, new input shaft, new slave cylinder setup not to mention the lines and such. You will have close to 1k in just parts to make it work. For that unless you put large windows in the side of your LT1 block I'd rebuild it and be able to reuse what LT1 tranny stuff you have.
Old Apr 6, 2006 | 05:23 PM
Ls1Bait's Avatar
Yea rebuild up that LT1. 383
Old Apr 6, 2006 | 09:12 PM
I Already Got The Ls1,rebuilding The Lt Is Out Of The Question Will My T56 Bolt Up To A Ls1 Bell Housing Theres One On Ebay With All The Parts For 250 Please Let Me Know Asap So That I Can Buy It.
Old Apr 6, 2006 | 09:13 PM
kossuth's Avatar
Yeah they will change over but you need to tear the whole thing down to do it. The middle case and tailshaft and all that are the same. Just the front plate and all that is different. Unfortunately that means setting up the entire transmission from scratch basically.
Old Apr 6, 2006 | 09:20 PM
sounds like i lot of work but i still think its worth it the ls1 works better from what i've seen buti dont want this to start a ls1 vs lt1 thread its just what i've seen.
Old Apr 6, 2006 | 09:40 PM
JonCR96Z's Avatar
The input shaft is a different length. you would have to disassemble the transmission. which if you dont know how, then its really gonna cost you to get it done. And why does everyone think that the LT1 has a cable clutch?
Jon
Old Apr 6, 2006 | 09:48 PM
i dont know but i do know mine doesnt
Old Apr 6, 2006 | 11:29 PM
am I spreading misinformation? I thought the T56 of the LT1's had a cable clutch. Last time I listen to something spuds says.. Am I confusing it with the mustang t56?
Old Apr 7, 2006 | 12:47 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
The Cobra T56 has a cable setup. LT1 has an external hydraulic slave cylinder like the old TPI 3rd Gen F-body's and some of the TBI 5-speed GM trucks.
I also have a LT1 T56 with a fresh rebuild, and while I will be changing out the front plate and using LS1 bellhousing and slave cylinder... I'm thinking of keeping the LT1 input shaft but with a different pilot bearing (factory on '05 LS2 C6) as its been told to me that it takes up that extra .400" difference. I'll find a part number on it and post a pic up of the bearing.
Old Apr 7, 2006 | 06:47 AM
kossuth's Avatar
Good luck with that. Hmm .400" is alot to makeup for. If you are gonna go through the trouble to change the front cover and all that you might as well change the input shaft also. At that point what does $200 or whatever the input shaft cost actually gonna lose you. Also another thought. Clutch disc splines? Is the spline count and diameter on the LT1 the same as the LS1? I don't know but I thought it would be a good question to ask. What about spline engagement? Will the spline go onto the disc far enough?
Old Apr 7, 2006 | 08:57 AM
Project GatTagO's Avatar
The LT1 T56 transmission are getting hard to find and are rather desirable for guys that want to install it behind old school small blocks and big blocks. You best bet is to unload the LT1 T56 and get an LS1 T56. A salvage yard that specilizes in late model pull outs may even swap you straight for it. There are way too many differences between the 2 transmissions.
As for spline count, that is the same, 26 spline. If you managed to convert the LT1 T56 to an Ls1 style T56, then you would simply use an LS1 style clutch. The LT1 clutch is very different. It uses a pull style diaphragm vs the push style for the LS1.
Andrew
Old Apr 7, 2006 | 09:03 AM
93Polo's Avatar
Any interest in selling the LT1 t56? Where are you? Let me know
Old Apr 7, 2006 | 10:44 AM
-Joseph-'s Avatar
Its no big deal either way, the input shaft is the only thing I don't already have and with the way I've been spending money, $200 would be one of my cheaper purchases, lol. The pilot length is the only difference. It may/may not even work, but I'd like to know. As others have said maybe its best to just sell the LT1 T56 or trade for a LS1 T56.
Old Apr 7, 2006 | 06:47 PM
i'll sell my lt1 t56 it has a brand new center force clutch but i dont have a clue whats it worth?
Old Apr 7, 2006 | 07:20 PM
95/02ss's Avatar
can i be second in line for the motor/tranny
thanks
Old Apr 7, 2006 | 10:30 PM
shr00m-dew's Avatar
Andrew
Andrew's right. I had a LT1 style behind my stock TPI. When I went to the LS1 I swapped to the LS1 style T56.
I went from a high mileage, stock clutch, LT1 style to a 40,000 mile, DF clutch, and Mcleod adjustable master LS1 style and actually made about $400..
Kevin D.
