VATS Removal?
Launchin It!
I just had the VATS removed from my PCM programming and what is the procedure for removing the black box with the red light? Do I just cut it out of the harness or do I have to join the two wires together now? This is that little black box with the resistor in it and a red LED light that always stays on.
I'll try to find a picture.
Yeah its not spliced inline anywhere. Cut the wires off and tape. For the best look cut the splice out and shrink wrap. Want to sell it? I need one...
-Alex
-Alex
Launchin It!
-Alex
-Alex
Conversion master
Its not a resistor. It is a 5V 50Hz square wave signal generator. There should be 3 wires, power, ground and signal. Just chop it off and heat shrink over the wires.
Moderator Note - It doesn't matter for what your'e doing, Buddy, just wanted to let others know that may look at this thread.
