Viper T56 to 99' LS1
Old Apr 8, 2006 | 10:35 AM
bczee's Avatar
Default Viper T56 to 99' LS1
I am looking into a Viper T56 that has been converted to a GM Input shaft. But I noticed that the Hyd Throw out Bearing bolt holes are not in the same location as the GM. They look like they are (looking from the front) rotated 90 clockwise, 2 and 8 o'clock vs the GM location 11 and 5 o'clock.
See attached pictures of the converted Viper T56 and the F-Body TOB.
Does anyone know of what mod or part there is to get this to work ?
thanks
Attached Thumbnails Viper T56 to 99' LS1-dcp_3575.jpg   Viper T56 to 99' LS1-im002705-s.jpg
Old Apr 8, 2006 | 04:34 PM
76LS1BIRD's Avatar
Restricted User
Can you use the viper TOB ?
Old Apr 8, 2006 | 05:21 PM
Brains's Avatar
Either use the Viper release bearing, or a drill
Old Apr 8, 2006 | 06:07 PM
bczee's Avatar
Will the Viper TOB hyd slave match up to the 99' F-Body master, that being the GM Quick Disconnect?
Can or do I have to use the Q/D and Bleed screw off of the GM and on t the Viper TOB?
Old May 12, 2006 | 12:32 AM
bczee's Avatar
I have solve my problem.. had a thread in the Manual Trans forom.. check it out if you want to know what I did to resolve it.
https://ls1tech.com/forums/manual-transmission/503808-t56-gm-viper-throw-out-bearing-slave.html
Old May 12, 2006 | 08:14 AM
Brains's Avatar
Nice work, that'll work great!
