LS2 Swapped Porsche 911 Widebody. Project<Pics.
#62
Originally Posted by J-Rod
A porsche 911 equipped with the LS1 conversion and ToyJet cooling system installation yieilds a
combined weight savings of 21 pounds lighter at the rear of the vehicle.
Hence:
No added cost of beefing up your rear suspension to off set any added
weight.
Hence:
weight.
#63
I LOVE THIS PROJECT!
that bodystyle is so badass, loved it since the first time I laid eyes on it as a kid. the widebody makes it look 10x better, oh yeah those beautiful wheels are soooo nice!
best of luck on the swap and keep us up to date with pics!
dont mind the haters, there are PLENTY of 911's runnign around, all stock, for the Porsche guys to drool over... its about time that '77 widebody 911 got an LS1 swap to get the modern powerplant it deserves!
props!
I just love it! WOOOOOOOOHOOOOOOOO!
props!
#66
The 911 V8 swap is a fantastic idea. The 911 platform is light (just like the RX7, only less). You spend a ton of money on a 911 turbo charge it, and you make as much HP as a stock Ls1 (and it weighs the same). You can take an LSx motor with the kits that are out there, and bolt it in. The cooling is the only issue. You either cut the front of the car, or do a toy jet wing radiator. Early 911s can get down aroud 2200 lbs if memory serves me. So, imagine a 2200 lb car with a decent LSx motor. I have several friends who have kicked the idea around. Most aren't wild about cutting the car up to get a radiator up front.
Anyway, this car runs around the Houston Area. It was done several years ago.
The other companies that do V8 swaps like Renegade are not producing any kit either.
#67
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Great concept. I'd like some more info on the cooling as well. I went to the Toyojet website & the pics are small/low res- few details as to how this is set up.
Since I own two rear engine air cooled 6 cylinder Chevys, this idea appeals to me for one of them. The 4 speed transaxle from the mid 60's is no fun on the highway after having driven a car with a T56. Almost all of the V8 swaps for these cars involve cutting out the rear seat area & making a mid-engine, with a few rare 215 CID Buick/Rover V8s in the engine bay or Olds 455s & auto transaxle under the rear shelf.
I had a mid-engine concept of running two small radiators under the quarter windows & plumbing them together, but never went further with this idea. The German body style would not allow this configuaration at any rate.
I was looing at the Renegade kit for a 928 & may still do this one at some point.
#75
Here are the pics as of today.
Forged Eagle 3.900 crank, forged H-beam 6.125 rods, custom Diamond 4.00 pistons yeilding 392ci.
317 heads with full CNC porting and hand cleanup/ bowl blending. Manley 2.08/1.60 valves. Comp Cams 921 dual valve springs, seats, Ti retainers, and perf locks.
![](http://home.comcast.net/~taylortsims/CIMG1012.jpg)
![](http://home.comcast.net/~taylortsims/CIMG1015.jpg)
LS2 stroker build up.
![](http://home.comcast.net/~taylortsims/CIMG1154.jpg)
![](http://home.comcast.net/~taylortsims/CIMG1161.jpg)
![](http://home.comcast.net/~taylortsims/CIMG1162.jpg)
![](http://home.comcast.net/~taylortsims/CIMG1170.jpg)
![](http://home.comcast.net/~taylortsims/CIMG0906.jpg)
![](http://home.comcast.net/~taylortsims/CIMG1225.jpg)
#77
Big Stuff 3 stand alone engine management system with wide band and internal Data logging.
![](http://home.comcast.net/~taylortsims/CIMG1053.jpg)
Cooling system componets and universal street rod kit from Classic Auto Air.
![](http://home.comcast.net/~taylortsims/CIMG1122.jpg)
![](http://home.comcast.net/~taylortsims/CIMG1123.jpg)
4 Piston Brembo and Zimmerman brake upgrade on all four corners.
![](http://home.comcast.net/~taylortsims/CIMG1217.jpg)
![](http://home.comcast.net/~taylortsims/CIMG1220.jpg)
Custom Strut tower braces from .75" 6061 Al.
![](http://home.comcast.net/~taylortsims/CIMG0972.jpg)
