power steering delete
Old Apr 22, 2006 | 12:25 AM
malibuman69's Avatar
Default power steering delete
I was wondeirng how the belt should be routed taking the ps pump out. all i have is the water pump, alt, crank pulley, idler and tensioner. thanks a bunch
Old Apr 22, 2006 | 03:11 AM
67RSCamaroVette's Avatar
I'd do it like this, but add a grooved idler pulley in the stock location above the alternator.
olly
Old Apr 22, 2006 | 08:07 AM
BigD's Avatar
Are you running an F-body or C-5 brackets?
Old Apr 22, 2006 | 08:30 AM
I believe they are F-body brackets. The engine is a ASA LS1.
Old Apr 22, 2006 | 09:30 AM
what size belt was that you used 67RS
Old Apr 22, 2006 | 01:38 PM
I added P/S.. to measure the belt I used a piece of wire (the crappy white wire that came with my pacesetters for "O2 extensions", wrapped it around, and subtracted 1/2" and it fit perfectly.
Old Apr 22, 2006 | 02:51 PM
awesome. thanks a bunch for the help. it had me confused on what to do. i cant clear a ps gearbox, so there is no need for the pump. thanks again for the help!
