Wiring Harness info.
Here's where I'm at, the car will have absolutely no ammenities, no heaters, no a/c, only P/S and Power brakes. I'm running a custom column, interior is cage, racing seats, and aluminum dash with autometer gauges, custom column, and I plan on running a switch panel to control everything (lights, start, etc)
What should I do about a wiring harness for the car? If I custom made one which wires do I still need, where can I find a diagram to custom make one? What have the rest of you done?
Pat
These are some pinouts from another post
99 LS1 PCM to Dash Harness
White (220) Plug
A TAN Oil Pressure
B GRY PCM 32 Clutch Anticipate Switch Signal
C PNK C105-B IGN Power for TCC Stop Lamp Switch
D PPL PCM 33 TCC/Cruse Brake Switch
E BLK/WHT Ground
H ORN/BLK PCM 34 PNP Switch Signal
J YEL/BLK Low Coolant Indicator
K DK GRN/WHT PCM 50 VSS Output
Blue (230) Plug
A GRY PCM 46 5V Feed (Fuel tank pressure)
B Brown w/Stripe PCM 25 MIL Lamp Control
C WHT PCM 45 EVAP Canister Vent Valve Control
E Blue PCM 55 Theft Deterrent Fuel Enable
F DK GRN/WHT PCM 17 A/C Request
G GRY PCM 23 Fuel Ground
H DK GRN PCM 64 Fuel Tank Pressure
J PPL PCM 54 Fuel Level Input
K DK GRN PCM 58 Serial Data (Class 2)
99 LS1 PCM to Front Harness
Large Plug C100 Plug
A PNK Hot in Run and Start (IGN/INJ Bank 1 15A)
B DK GRN/WHT PCM 43 A/C Clutch Relay Control
C DK GRN PCM 18 A/C Clutch Status
D GRY TPS +5v to TCS
E DK BLU TPS signal to TCS
G PNK Hot with IGN 1 Relay Engaged (Tranny/EGR 15A)
H DK BLU PCM 33 Cooling Fan 2 and 3 Relay Control
J DK GRN PCM 42 Cooling Fan 1 Relay Control
K BLK TPS sensor low to TCS
C101 Plug
A YEL/BLK Low Coolant Sensor
B PNK Hot in Run and Start (IGN/INJ Bank 2 15A)
C BRN PCM 36 Air Pump Relay Control
D DK GRN/WHT PCM 9 Fuel Pump Relay Control
E PNK/BLK PCM 19 Ignition Positive Voltage for PCM
G ORN PCM 57 Battery Positive Voltage for PCM
H BLK/WHT Ground
K GRY/BLK PCM 53 TCS Spark Retard Signal to Brake Control Module
C105 Plug
B PNK Hot with IGN 1 Relay Engaged (TCC Stop Lamp Switch/MAF/O2 20A)
D DK GRN PCM 37 Cruise Control Inhibit
F WHT PCM 13 Cruise Engaged Signal
G WHT PCM 10 Tach out to Brake Control Module
H PPL PCM 4 AIR Solenoid Relay Control
These are all of the pins/wires I did not use:
220- E,H,J,K
230- A,C,F,G,H,J
C100- B,C,D,E,K
C101- A,C,K
C105- D,F,H
(thanks to StngKlr for the pinouts)
I attached a post by Mr Dude_1 the connections for a 3rd gen camaro are there.
Are there any differences between Camaro and WS6 PCMs?
