I need to make a custom plug wire
Old Apr 25, 2006 | 08:27 AM
Stu Cool's Avatar
Default I need to make a custom plug wire
I asked this question over on the External Engine forum and did not get a response. I need to make one custom plug wire to get around a header tube. What have you folks with custom plug wires done about the coil end of your wires? I took an old one apart hoping to reuse the terminal end, but it does not seem possible. I need either a 90 or 135 degree end on the spark plug side, those I think I can figure out.
thanks
Pat
Old Apr 25, 2006 | 09:54 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
If you just need one of these terminals and can't find one locally let me know and I'll send one out to you.
I keep some around for the same reason; some projects require a plug wire that they just don't make!
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Apr 25, 2006 | 10:03 AM
Stu Cool's Avatar
Thanks John, the folks at Taylor wire said they will send me a couple. If that does not work out, I'll send you a note. What about the white plastic piece that slides over them?
thanks
Pat
Old Apr 25, 2006 | 10:29 AM
Speartech's Avatar
I don't have those. I've noticed that some of the aftermarket wires skip that part altogether. I think the main purpose is to keep the small terminal centered in the big boot so it all plugs onto the coil easily. You can either reuse the original or not use one at all.
__________________
www.speartech.com
Old Apr 25, 2006 | 11:36 AM
Stu Cool's Avatar
Thanks! I owe you, and many others a beer or whatever
Pat
