engine mounts ls1 into 94 camaro
Old Apr 26, 2006 | 06:02 AM
1994z's Avatar
Default engine mounts ls1 into 94 camaro
what engine mounts did yall use to set the ls1 in. anybody use a front motor plate.
Old Apr 26, 2006 | 10:09 AM
NemeSS's Avatar
word of advice just get a used ls1 k member from somebody
or if u got few extra $$$ use a tubular k member
its like 50 lbs lighter and u have more room for turbos
Old Apr 26, 2006 | 10:35 AM
01WS6/tamu's Avatar
You will also have to go with an ls1 rack and pinion the steering shaft entry angle is off with an lt1 or v6 97 back.
Old Apr 26, 2006 | 08:28 PM
1994z's Avatar
would the arms from the lt1 work. or do i need the ls1 stuff. this is for a 94 camaro drag car only
Old Apr 30, 2006 | 11:38 PM
gogogadget's Avatar
The control arms will bolt up fine.
Old May 1, 2006 | 06:00 PM
Yellowbrother's Avatar
i got '00 camaro front cross member and t56 tranny mount if interested...i live in houston...
