What radiator are you using
Old Apr 27, 2006 | 08:57 AM
Glock36's Avatar
Default What radiator are you using
What radiator are you using in your swap are there any to stay away from?
Old Apr 27, 2006 | 09:31 AM
Scooter70's Avatar
Griffin Universal fit 31x19 from Summit with Flex-a-lite twin electric fans. No cooling problems here.
Old Apr 27, 2006 | 10:59 AM
Steve68's Avatar
I was going to use a Ron Davis, with built in Spal fans, but I saw a Afco thats nice too,
Old Apr 27, 2006 | 12:26 PM
Schitzo's Avatar
stock radiator for a 71 camaro.....it is almost new and kept my old 350 very cool. It also has a fitting for the line that goes to the heads....all I did was have the rad shop guys lower the inlet pipe a few inches so that I could use a stock hose and clear the intake pipe.
Old Apr 27, 2006 | 12:29 PM
Slo_240sx's Avatar
What fans are you guys using? I dunno if the Dual Autozone Special on this one lol.
-Alex
Old Apr 27, 2006 | 12:36 PM
Schitzo's Avatar
stock ls1 fans
Old Apr 27, 2006 | 12:56 PM
bczee's Avatar
Was looking around on eBay.. eBay store Univeral Parts Inc. I saw a nice setup.. I think this one will work for you 67 Camaro, has Alum. Radiator and dual fan. Thinking of getting one for my Chevelle.
http://cgi.ebay.com/ebaymotors/1967-...6692QQtcZphoto
Old Apr 27, 2006 | 12:57 PM
malibuman69's Avatar
fluidyne (normal gm size) with a single 16in fan. no cooling problems yet.
Old Apr 27, 2006 | 02:29 PM
MrDude_1's Avatar
im using my stock 91 camaro radiator, and the stock single fan. stays very cool
Old Apr 27, 2006 | 02:49 PM
67RSCamaroVette's Avatar
Stock ellisjuan rad, stock dual fans, cleaned up a bit.. it was dirt cheap and aluminum, fit perfectly, and will work for sure.
olly
Old Apr 27, 2006 | 03:21 PM
Steve1969LS1's Avatar
AFCO Radiator
Old Apr 27, 2006 | 04:58 PM
Steve68's Avatar
Steve, how about the hook up on the AFCO source, Thank you,
Old Apr 27, 2006 | 11:46 PM
patriot68's Avatar
alumrad.com
Old Apr 28, 2006 | 05:24 AM
V8 Supra Builder's Avatar
Used the Jags That Run recommended plastic/aluminum six cylinder (4.3) 1990 Chevy G10 Van radiator on the 280Z along with the HUGE fan from a Lincoln MK 8. Very minor trimming to the fan shroud, it fits the core of the radiator almost perfect. Haven't run it yet, but looks like it will do the job here in FL. Radiator was a little over $100 at www.rockauto.com and I picked up the fan used by using Google (to find a Lincoln MK 8 website and a guy parting his car) for $80 shipped.
Measured the Supra & I think I can fit either an F body or Vette stock radiator & fans into it, since the frame rails are wider than on the 280Z.
Old Apr 28, 2006 | 08:55 AM
stealth71's Avatar
I'm ordering the Summit 31x19 w/ Mark VIII fan should keep nice and cool. Only about $300 for the setup.
Old Apr 28, 2006 | 09:46 AM
Oscar Will's Avatar
I'm running a new Walker radiator with a Cooling Components molded shroud and 16" single speed fan. Ran 190 degrees in traffic on the Strip in Las Vegas.
By Brett Foote | 2026-06-04 05:00:17
