98 Silverado swap. Need help
I think you have to keep the old PCM to run some things like the ABS brakes.
The L31 Vortec v8 has pretty darn good heads, and there are ALOT of performance parts out there for a SBC that will fit up. For the money you'd spend to swap in a fairly stock LS1, you could have a really hot L31 (or just spend less money). 400 hp shouldn't be that hard to get out of the L31, now that guys have figured out the EFI manifold swap problem (factory EFI manifold runs out of fuel and you can't change injectors, solution is to change to the Mercruiser EFI manifold, which uses individual injectors).
'JustDreamin'
