Can I do this?
Old May 7, 2006 | 02:36 PM
billyjo's Avatar
Default Can I do this?
I'm test fitting my 6.0 into my 72 K/5 Blazer and have run into a problem. There is an aluminum boss off the side of the pan that is keeping it from sitting all the way down in the engin cross member (See pic). Can I just grind this boss off and the one on the block right in front of it without having any problems?
Old May 8, 2006 | 03:13 AM
blazerboy72's Avatar
Is your blazer 2wd or 4wd? From the pic it looks like 4wd but I cant tell. In mine I used the performance online motor mounts and everything cleared fine but mine is also a 2wd.
Old May 8, 2006 | 07:14 AM
billyjo's Avatar
Mine is a 4x4 the crossmembers are different between 2x4 and the 4x4. I originally bought a set of mounts from classic chev but they weren't even close thats how I found out about the difference.
