little wire help please
Old May 12, 2006 | 07:04 PM
68shortstep's Avatar
Default little wire help please
neutral safty switch for a 00 c1500 p/u
what do the wires connect to for the top connection? i.e. power, brake switch,etc......???? i have no idea so can some one tell me what they connect to....
2 lt green
1 pnk
1 purple/white
1yellow
1 black/wht ( i know this one is a ground)
Old May 12, 2006 | 09:30 PM
G-Body's Avatar
sawzall wielding director
Um I don`t know . Well not exactly at least, I did not use them for anything on my conversion, I think they are for the reverse lights, and mabey the starter lockout so that it will only start in park or neutral. They are not on my chiltons diagrams for the motor wiring (only the other connector on the switch is) I will see if I can find a diagram.
Old May 12, 2006 | 10:24 PM
thanks man... thats the same luck im haveing too.
Old May 13, 2006 | 06:44 AM
Jones'n's Avatar
Yellow and Purple/White are the starter relay feed. That is your Neutral/Safety. The circuit is closed in P and N.
The Pink is Ign Power Mainly for Pin F (Green) B/U lamps. The circuit closes in R to feed power to the B/U Lights.
The other Green wire (B) is for Shift Interlock... Nothing you will need.
A -- -- Not Used
B LT GRN 275 Transmission Mounted Neutral Safety Switch Output - Park
C PNK 839 Fused Ignition 1 Feed
D BLK/WHT 451 Engine Control Module Ground
E PPL/WHT 1035 Starter Relay Feed - Coil
F LT GRN 24 Back-up Lamp Feed
G YEL 1737 Transmission Mounted Neutral Safety Switch Output - Park/Neutral
Old May 13, 2006 | 11:38 AM
thats what i was lookin for thanks
Old May 15, 2006 | 10:57 AM
Jhankinson's Avatar
So pin D...is that grounded all the time or just in Park and Neutral? Is that the actual Park/Neutral ground signal the computer uses?
Old May 15, 2006 | 11:48 AM
im 99.9999% sure its grounded all the time...
Old May 15, 2006 | 12:08 PM
Jones'n's Avatar
Yep, it gets grounded all the time.
No, it isn't used by the PCM in your case.
Old May 15, 2006 | 01:53 PM
Jhankinson's Avatar
Is there any other place I can get this...or is the ground in Park/Neutral even really needed for anything. It is one of the wires I have to hook up...but have just been running with it unhooked...this wont cause a problem will it?
Old May 15, 2006 | 02:12 PM
Jones'n's Avatar
Nope... nothing that you need hooked up.
