PCM Outputs - High or Low?
Old May 15, 2006 | 04:40 PM
Happy Jim's Avatar
Default PCM Outputs - High or Low?
Hi all,
I'm just finishing up my home made loom and a thought occurs Does the PCM signal a change in state as +12V or Earth?
Only critical on Fan1 - Fan2 & Fuel pump, as I'll be pushing these through relays.
Thanks
Jim
Old May 15, 2006 | 05:08 PM
Schitzo's Avatar
for the fuel pump 12v for the fans ground (earth)
70 LS1's Avatar
Conversion master
Depends on the function. Some are active high and some are low. For the fans the PCM grounds the 3 relays turning them on.
Don't know on the fuel pump.
Old May 15, 2006 | 05:09 PM
70 LS1's Avatar
Conversion master
Damn, beat me to it.
Old May 15, 2006 | 07:42 PM
ghettocruiser's Avatar
On a related note... About those fan relays. Im curious because Im working on the same thing right now... Why are there three relays for the fans??? There are only two cooling fans, but three relays. Also...in the pin outs that I have for a 99...they mention Fan High Output... Fan Low Output... What is the high/low they are referring to?? Thanks...
Justin
Old May 15, 2006 | 07:53 PM
70 LS1's Avatar
Conversion master
Check out the schematic. When the Fan Low Output goes low it will energize the two fans in series so each fan only gets 6V. This will make the fans run in slow speed. When both the Fan Low Output and Fan High Output go low, they will energize the fans in parallel with each fan getting 12V.
Old May 15, 2006 | 08:32 PM
88s10's Avatar
fuel pump is 12v fans are ground and mil light is ground signaled from pcm. hope that helps
scott
Old May 16, 2006 | 07:26 AM
Happy Jim's Avatar
Guys,
As ever - many thanks, saved me from frying wires
Jim
Old May 16, 2006 | 07:49 AM
Hmm..ok. That makes sense.. So on an LS1 car, at a certain temp, both fans come on at 6V rotating at a slow speed. Then when the temp rises to another point, they both get full 12V and rotate at full speed. Is this basically correct? So when I wire this up...I should wire it the same way as stock...and both fans will always operate together?>?
I was under the impression that I should be running off of one fan at full speed, then at a certain temp have the second fan come on..or with the A/C...
Thanks for the drawing and the info!!
Justin
Old May 16, 2006 | 08:09 AM
Schitzo's Avatar
Justin
this is how I will be running my fans. It is a simple setup and works just fine
Old May 16, 2006 | 10:10 AM
70 LS1's Avatar
Conversion master
So does the stock setup with 3 relays. its only one more relay and is completely controlled by the PCM.
Old May 16, 2006 | 02:57 PM
Schitzo's Avatar
now that I have looked at it closer, I think the stock setup is better since both the fans are always running. The schematics were alittle bit confusing at first but now I get it..
