Engine Level or narrower transmission?
Old May 20, 2006 | 12:39 PM
mramay's Avatar
Default Engine Level or narrower transmission?
Trial fitted the plastic LSx engine with a GTO front sump oil pan and empty 700R4 (4L60E) transmission housing into my Benz. The transmission is about one inch too wide (13") to fit up in the tunnel. If I leave the transmission below the tunnel opening, the engine is sitting at an angle in the engine bay, nose high and looks like it will make a rather interesting angle for the driveshaft to accomodate. I didn't really want to modify the floor pan of the Benz as it's multiple layers thick under there and very strong. I might be able to modify the pan to drop the engine an inch or so.
So, here's the question: can an LSx operate somewhat nose high or is there another automatic transmission that will take an LS6 output but is narrower than 13" across the pan?
Thanks,
Mike R.
Old May 20, 2006 | 01:07 PM
350SS's Avatar
I'm not sure about it being narrower, but a 2004R transmission is definitely shorter and still has overdrive. See the dimensions here: http://www.tciauto.com/tech_info/trans_dims.htm
They can be built to handle the power behind a built turbo V6 so they should be able to handle and LS6 too. Do you need to run a front sump pan like the GTO pan or can you use a F-body pan? If so the stock F-body pan might work or you might be able to use the Street and Performance modified (clearanced) pan or I think John B has a guy that can modify them. There's probably more info on the pans in the stickys at the top of this forum.
Max
Old May 20, 2006 | 10:13 PM
67RSCamaroVette's Avatar
Use a BFH for the transmission tunnel. Works great.
Old May 20, 2006 | 10:34 PM
mramay's Avatar
Thought about that but the Benz has multiple layers of sheet metal on the tunnel and the transmission bolts to that metal under there - STRONG metal. The other reason to try to find another solution is that there are several other Benz owners that are waiting for me to do an LSx conversion and they want to do it also.
There is interest in a kit for my "LSx into Benz" work, and I really don't think including a five-pound hammer in the kit would be looked upon as a reasonable solution! :-)
Good idea though.
Old May 21, 2006 | 12:59 AM
aww comeon, a singlejack is a man's best friend. next best thing is get a cutoff wheel and fabricate/find a tunnel that can fit.. or a transmission that doesnt affect clearance, like 350ss said...
Old May 21, 2006 | 07:50 AM
LS1 Hybrid Magna's Avatar
People waiting hahaha!
2. vote for the 200R4! But its low tech and i think a Benz owner would love the new features a 4L60E and up transmissions have on the CPU side.
I guess the way to correct the angle is the K-member and Oilpan choice !
Will talk about the strg rack to my Buddy on Monday
Old May 22, 2006 | 12:50 AM
mramay's Avatar
Thanks for pushing your suggestion again!
I went back out and took another look at the clearance problem and it looks like I only need another inch in width for maybe 4 inches at the front of the tunnel. I'm not thrilled with the idea of using a BFH, but I think a bottle jack (singlejack?) would do the job. Same result, move the metal out of the way of the transmission. That way I keep an electronic transmission in there, which is a good thing.
Old May 22, 2006 | 08:41 AM
Stu Cool's Avatar
Instead of a bottle jack see if you can find a porto-power. You may be able to rent one. Since it is designed for body work it will do much better than a bottle jack. I agree the best solution is to modify the tunnel, even if you have to cut a small section out and put some new sheet metal or even fiberglass in there. Having the engine placed properly is critical to a smooth running car, especially in a high performance application. My $.02
Pat
Old May 22, 2006 | 08:59 AM
MrDude_1's Avatar
you could use a porta-power, (kinda like a specialized bottle jack) but i would just cut the tunnel and mod it.
sure its "strong metal" but its still no match for normal cutting tools.. yea it'll be a PITA welding back together, but its not impossible.. doing it this way will yield the nicest result..
Old May 22, 2006 | 11:13 AM
mramay's Avatar
Pat
I forgot about Porta-Power! That would be the easiest way to do the job as I'm not a welder nor have any welding equipment, but I do have plenty of shop air. I was concerned since I can't get the car very high in the air in order to swing the BFH, but a porta-power "adjustment" could be done with the car on jackstands.
Great suggestion!!
Off to the yellow pages,
Mike R.
Old May 25, 2006 | 03:04 PM
LS1Cobra's Avatar
If it's a one spot the hammer trick should be OK. If it's the whole tunel I would cut it out and get your drivetrain set and then take it to someone fab up another piece of metal and weld it back in. GL
Old May 25, 2006 | 03:16 PM
mramay's Avatar
It appears that if the tunnel is pushed out 1" wider for about 4" long at the front of the tunnel, the tranny might fit.
I'm using a plastic LS1 engine with the GTO oil pan and an empty 700R4 transmission housing to do sizing, motor mounts, etc. Since I'm working out of town, I have had very little time to mess with the Benz to figure out things like this. In fact, since I put the engine/tranny in there, I haven't had enough time to even jack the car up enough to really get under there to see what's happening. Not good progress so far. :-(
I can look down from the top and see the interference, but it's going to take a short trip underneath to determine the extent of the problem. Maybe this weekend I can put it up on jackstands and get under there to see exactly where the interference is occurring and how much the tunnel actually needs to be moved.
Thanks for the suggestion though.
Mike R.
Old Jun 25, 2006 | 04:19 PM
mramay's Avatar
Harbor Freight Tools had a 4-ton porta power on sale that just fit inside the tunnel. It took about an hour to push the tunnel out wide enough for the 700R4. A little primer and paint and it's going to be ready to go
thanks again for the suggestion!!
Mike R.
Old Jun 25, 2006 | 05:17 PM
LS1MCSS's Avatar
The problem with the 200-4R is getting the throttle valve cable to work correctly. If it doesn't work right, the tranny will burn up real quick.
