specific year of block?
Old May 21, 2006 | 08:34 AM
chevrev's Avatar
Default specific year of block?
how do i find out the specific year of my ls1 block? from running the numbers, i have narrowed it down 99+.
thanks,
shad
Old May 28, 2006 | 11:39 AM
John B's Avatar
Moderator
If you get a hold of a wrecking yard or someone who has the Mitchell interchange books they can probable track it down for you.
Old May 28, 2006 | 09:10 PM
Mr.Nitrous's Avatar
You can usually find the vin #'s on the rear of the block by the rear ear where the trans bolts on to. On the driver side on the bottom. You should be able to contact your gm dealer and they should be able to help you out once you have the #'s. Good luck
Old May 28, 2006 | 10:46 PM
fast377's Avatar
It's a laser etched number and usually hard to see. And it is an ENGINE VIN. If you do a google search, there is a website that can decode that number. If you take off the rear main cover, look and see if the block has an opening that matches the opening in the gasket. It's right above the cam. The 97-early 99 did not have this opening. the late 99-02 did.
Old May 28, 2006 | 11:44 PM
Mr.Nitrous's Avatar
Yes that's what iI did but don't remember the what site I found the info on.
