LS2/57 Belair needs fuel lines
Old May 23, 2006 | 08:30 PM
jim57's Avatar
Default LS2/57 Belair needs fuel lines
Well I'm ready to run the fuel lines. Will need a new tank must be mounted 3 in farther back to clear the Corvette rear end and have in tank pump. I want to run stainless steel from tank to fuel rail, what about the return, never had to worry about it in the past. Will I need to put on an unvented cap?
Thanks,
Jim
Attached Thumbnails LS2/57 Belair needs fuel lines-dsc01877.jpg   LS2/57 Belair needs fuel lines-dsc01883.jpg
Old May 28, 2006 | 11:46 AM
John B's Avatar
Moderator
Lookin' sweeeeeet! It all depends if you want to use the '99 & up C5 filter for a return line or the dual feed C5 '97-'98 fuel rail which has the return line right on the fuel rail. If you decide on the dual feed fuel rail, I have one advertised here https://ls1tech.com/forums/lsx-parts-sale/508043-97-98-c5-dual-feed-fuel-rail-5an-6an-brazed.html
Old May 28, 2006 | 09:38 PM
patrick_rodgers's Avatar
Am using a full return line. Will need a small piece of braided / rubber line to and from the hard lines.
