Moped Engine Swap....seriously
Old May 30, 2006 | 02:28 AM
Keith's Avatar
Originally Posted by crafty888
How about some more info on those.
Old May 30, 2006 | 08:58 AM
67RSCamaroVette's Avatar
rotary airplane engine is bad ***. Not much ground clearance for that cylinder head, though. I'd have to go with the dual-jet moped.
Old May 30, 2006 | 10:49 AM
MrDude_1's Avatar
how about a turbo suzuki 4stroke in a YSR?
Optimus_Prime:
luckily, its not hard to fix your problem realisticly...
they put limiters and restrictions in the bikes already.. if it has a speed limiter, you can disable that... most likely it has a large baffle/restrictor in the exhaust.. ditch the muffler and replace it with a open dirtbike one.. (or other compact muffler.)
if you want to start getting into it, replace the tiny carb with a bigger one off of a dirtbike...
oh, and theres always nitrous (no, im not kidding... you can do it easily.. lol)
Old May 30, 2006 | 11:33 AM
diognes56's Avatar
You could also go this route . You know what they say: If it is good enough for Leno..................... http://www.marineturbine.com/motorsports.asp .
David
