ecm question
Old May 30, 2006 | 12:03 PM
92slowmaro's Avatar
Default ecm question
ok i have a question and i dont think anyone has talked about it. once i get my ls1/t56 into my 92 camaro do all the wiring with a stand alone harness. what needs to be modified in the ecm. like what needs to be deletted or changed. and even will the car start if the ecm is straight out of the donor car? just wonder what it would take to start it once everything is done.
thanks
ryan
Old May 30, 2006 | 12:31 PM
Brains's Avatar
This has actually been covered dozens of times The first thing is you'll need to program out the VATS so the car will stay running -- or use a VATS eliminator module. Beyond that, you program according to your particular setup.
Old May 30, 2006 | 12:32 PM
stealth71's Avatar
It's been covered. Depends on if you keep emissions, VATS, .....
