my 1st gen swap
Old May 27, 2006 | 12:30 AM
leonpiper69's Avatar
Default my 1st gen swap
i know these are pretty common now, but i wanted to post some pics kuz im pround of it. so far i paid someone to put quarters on it.............they messed it up. turns out there was another layer of sheetmetal they didnt remove. i've never done quarters but i wanted it done right so now i just finished tacking them in place. took me about 4 hours each to fit properly. i got an 01 ls1 that makes about 500 horse, with a 4l60e with a 3500 yank converter. i still need a few parts, but i just got my motor mounts and tanks inc in tank walbro 255 set up. i already put new floors inside and in the trunk(that was alot easier than the quarters.
Attached Thumbnails my 1st gen swap-body-before.jpg   my 1st gen swap-newleftquarter.jpg   my 1st gen swap-newquarters.jpg
Old May 27, 2006 | 12:46 AM
67RSCamaroVette's Avatar
looks like an awesome start! good luck!
Old May 27, 2006 | 01:19 AM
thanks, i got most of my swap info form your sticky. i got the russel fitting and the corvette fuel filter. as well as that tanks in set up, i even got the block adapters because of your sticky. so hats off to ya dude.
Old May 27, 2006 | 07:05 AM
SatisTraction's Avatar
wow our cars could be twins. i am doing all the hard stuff too. check my links
Old May 27, 2006 | 08:12 AM
Steve68's Avatar
Looks good, Just keep going, you get there, I might,
Old May 27, 2006 | 10:55 AM
sati, man i checked your link. holy crap! thats aaaaaaaaaalot of work. im used to seeing cars that ruff back home(im from MA) but out here i guess i got lucky. looking good though, gives me hope. if you can get motivated to do all that, maybe i can at least go finish weldin my quarters on. this is the firewall after i painted it. and what kind of headers are those, there an awfully tight fit???
Old May 28, 2006 | 01:55 PM
those are self modified pacesetters. they actually fit pretty good
Old May 28, 2006 | 03:02 PM
chris, are you running a rack and pinion? I had to put a dent in my first header tube to clear my inner ball joint... after all that, getting them to clearance great with the steering box, the friggin first header tube hits the balljoint. did you have that issue?
Old May 28, 2006 | 05:15 PM
hmm, i have not checked that. :dang: i redone the complte front tube so it should be good but who knows. i iwll check in a couple days when i get a chance.
can you post up a pic of the area you are talking about?
Old May 28, 2006 | 11:48 PM
i'll take pics on tuesday.. it only hits when it crosses dead center. i mean it was soo perfect... cleared everywhere great.. now it hits.
Old May 29, 2006 | 04:10 AM
Rybar's Avatar
Good luck with your project. You got alot of work ahead, but it will be worth it in the end.
Old May 29, 2006 | 10:25 AM
billyjo's Avatar
I think the hardest part of a project is just getting start once your started it doesn't seem so bad. Looks great and keep us posted.
Old May 29, 2006 | 12:42 PM
today is a good day. i have an extra set of 373 gears on a posi carrier for an 8.5 ten bolt (i got it to put in my old 79 camaro). so ive been looking for a nova rear for those gears. well today i decided to take a look at what i got because i have been having trouble finding a nova rear. well at first glance i thought "oh schnap" thats an 8.5. so i wrote the #'s down and sure enough 74 nova. check it out baby.
Old May 29, 2006 | 01:08 PM
nice! I got one from a '76.
Old Jun 9, 2006 | 10:23 PM
i got motivated today .... so i modified my energy suspension mounts to fit the adapter plates, then painted them and went to get some more hardware.... but i was still motivated so i pulled off my big block frame mounts and put in my small block ones , and said f it and put my motor and trans in today. it was a little tricky kuz i ws alone and i put the driveshaft in the trans so it wouldnt puke when tilted. and here are some pics.
also im poor, so i learn as i go beacause i cant afford to pay for someone elses labor , so ive tigged steel before , so i figured ide try aluminum...........it wasnt that hard . i tried a scrap first and after 2 or 3 passes i felt good. but as you can see form the pic welding cast aluminum is a lot harder than the sheetmetal i used (thats why its a little sloppy) but please dont be too hard on me it was my first try.
Attached Thumbnails my 1st gen swap-adapter-n-mount.jpg   my 1st gen swap-motr2.jpg   my 1st gen swap-motr.jpg   my 1st gen swap-oil-pan.jpg   my 1st gen swap-motor.jpg
Old Jun 9, 2006 | 10:30 PM
nice! those welds dont look bad at all. be sure to leak check it using solvent (water wont always show leaks). You're doing the project just like me (and most of us) buying one part at a time. I bought a quarter panel, tail panel at a time until it got put together. You'll get there eventually. Dont give up, you're makign awesome progress.
Old Jun 9, 2006 | 10:39 PM
thanks, i dont give up easy. i paid someone to do my quarters and it turned out there was another layer of sheetmetal they didnt remove , so i couldnt get my doors to fit right. needless to say i had to spend a hundred and six bucks for 2 new qaurters and learn to do quarters. so like i said, i dont give up too easy. and the welds im proud of where the two pieces of sheetmetal meet, its where the sheetmetal meets the cast part that looks like poo!
Old Jun 10, 2006 | 10:02 AM
69blackwidow's Avatar
doing the same setup with my 69. its going good only had one problem, i went with a tremec tko not the t56. clutch set up was a bit*@. wish i could post some pics but can never get it to work. keep work guys, it will be worth it. mike
Old Jun 10, 2006 | 12:45 PM
Rybar's Avatar
Looking good, I wouldn't be embarassed about anything you did at all.
Old Jun 21, 2006 | 05:42 PM
i dropped in the motor and the 4th gen tts headers i have fit!!!!!!!!!!! although if i use these headrs i'll have to go to rack and pinion. or maybe shorties would fit???????? and then i could just trade these for some.....
Attached Thumbnails my 1st gen swap-mtr-.jpg   my 1st gen swap-driv-headr.jpg   my 1st gen swap-pass-headr.jpg
