Truck High mount A/C compressor bracket
Old Jun 2, 2006 | 02:02 AM
G-Body's Avatar
sawzall wielding director
Default Truck High mount A/C compressor bracket
These are a cuple of pics of my prototype A/C compressor mount. It mounts a 96 V6 camaro A/C compressor high on the passenger side. I will post more pics and dimensions after I make it out of aluminum.
Attached Thumbnails Truck High mount A/C compressor bracket-ac-mockup2.jpg   Truck High mount A/C compressor bracket-ac-mockup3.jpg   Truck High mount A/C compressor bracket-ac-mockup5.jpg
Old Jun 2, 2006 | 09:40 AM
ramair21's Avatar
Looks good... Cant wait to see it all done so i could buy one from you
Old Jun 2, 2006 | 10:56 AM
427ImpalaSS's Avatar
yeah I want to buy one also the aluminum version so it matches the rest of my LS engine, my wood engine will have to wait
Old Jun 3, 2006 | 01:20 AM
IOwnCalculus's Avatar
Yup...there's no reason some bracketry and pulleys should run $500+ I'll be keeping an eye on these.
Old Jun 3, 2006 | 02:51 PM
Kenova's Avatar
I built an altenator bracket for my SBC Nova using the same method. After a few trys making it out of plywood, I had one that worked perfectly. It was then just a matter of duplicating it in 1/2" aluminum. The chunk of aluminum cast me less than $40.00 and a few hours cutting and polishing it.
I'm pretty damn proud of that little bracket
Ken
Old Jun 3, 2006 | 10:17 PM
G-Body's Avatar
Yeah there was no way I was paying $500 for an A/C bracket that I could make myself. Plus I have not seen relocation brackets for the truck motors, just the vett/f-body accy drives. I figured I would post pics here and dimensions when I finnish it in case someone else needs something similar for their conversion. Now if only I had some aluminum plate , looks like I should get it next week.
Old Jun 7, 2006 | 11:42 PM
G-Body's Avatar
Well no aluminum yet, I have been sidetracked with other projects (had to replace the rack and pinion in my moms car). But I did do a second design of the bracket, in the first one I was not able to run the pulley on the factory tensioner if I had the belt for A/C on. The second design is spaced a little differently and solves this problem. But of course I was looking at it after I finnished and decided that I could alter the shape slightly and make it stronger so I guess I will be making another one out of wood before cutting aluminum. Heres a couple pics of the current design though.
Attached Thumbnails Truck High mount A/C compressor bracket-compressor-bracket-design2-pic3.jpg   Truck High mount A/C compressor bracket-compressor-bracket-design2-front.jpg   Truck High mount A/C compressor bracket-compressor-bracket-design2-back.jpg
Old Jun 8, 2006 | 10:11 AM
rnp.ent's Avatar
Default r4??
have you thought of using a r4 comp I'm working on a mount for mine ..
the r4 is larger dia but much shorter and will fit in front of the head..
just food for thought...
Old Jun 8, 2006 | 11:38 PM
G-Body's Avatar
A R4 compressor was my first thought since it was what my car came with, but I decided not to use one since I have had to rebuild more than a few, and everyone I talk to in the A/C industry says that they are not known for their durability. Plus I wanted to be able to keep my EGR valve since I have emissions tests here in illinois and it may slightly help my fuel mileage.
If you want to use the R4 compressor I would look at the way 5.3 Racer mounted his, he used a GM bracket.
Old Jun 8, 2006 | 11:44 PM
G-Body's Avatar
Here is the thread with 5.3`s setup, theres a pic on the bottom of the first page and a explanation at the top of the second.
https://ls1tech.com/forums/showthrea...ghlight=camino
Old Aug 25, 2006 | 08:19 PM
G-Body's Avatar
Well I finally got around to getting the aluminum cut out, drilled and tapped. I measured for the belt with string, but there was too much stretch in the string and the belt I bought was too short. Hopefully tomorrow I will be able to pick up the right one. Heres a few more pics.
Attached Thumbnails Truck High mount A/C compressor bracket-front-ac-bracket.jpg   Truck High mount A/C compressor bracket-rear-ac-bracket.jpg   Truck High mount A/C compressor bracket-complete-ac-bracket.jpg   Truck High mount A/C compressor bracket-acbracketandcompressor.jpg
Old Aug 25, 2006 | 11:18 PM
pt67camarols1's Avatar
I dont want to steal your thread but got a question. A few of us have the stock camaro LS1 compressor. If we want to make something smilar to this, can we change the head unit/pulley on the compressor to the large belt type to run on the engine belt?
Old Aug 25, 2006 | 11:28 PM
G-Body's Avatar
You might be able to, but I don`t know what kind of clutch pulley would fit on the LS1 compressor. You would have to use an A/C clutch pulley puller to remove your pulley and then go to self service junkyard and measure 6 rib serpentine A/C compressor pulleys. The LS1 compressor will also be more difficult to make a mount for since its bolt flange runs perpendicular to the belt/cylinderhead face, so you cannot use flat plate like I used. You would need to use angle aluminum, its not that it can`t be done, it is just more difficult. That is why I used a compressor from a V6 camaro, after looking at it I think it is the same compressor that was used on LT1 motors.
Old Aug 8, 2010 | 10:52 AM
Ford_Assassin's Avatar
Question
Digging up an old thread....
How did this workout?
I am looking for a high mount A/C compressor bracket(s) using the truck accessories (alt, crank pulley, no PS).
I like Kwik's, but I am limited with width clearances due to my strut tower.
Thanks!!
Attached Thumbnails Truck High mount A/C compressor bracket-dsc00133.jpg
Old Aug 8, 2010 | 11:15 AM
Jimbo1367's Avatar
I am interested in a AC mount too. But I don't want too much aluminum in my engine compartment. Would you be willing to sell me the wooden piece? It should last almost as well.
thanks,
Jim
Old Aug 20, 2010 | 10:40 AM
G-Body's Avatar
Thanks!!
I ended up abandoning it and notching the frame. It seemed like it was going to work well and felt plenty strong, but I could not find a belt that was the correct length as I didn`t really have a lot of room to move the comp closer/further from the motor. IIRC when I went for a belt I found out that when the belts get that long there happened to be a 3 0r 4 inch difference in length between the 2 closest sizes.....and I needed something right in between
thanks,
Jim
If I had any idea where that piece of wood went I would send it to you just to see it being run. I don`t think it would be nearly strong enough though. IIRC it was half inch plywood and would flex all over the place with just the weight of the compressor sitting on it for mockup.
Old Aug 20, 2010 | 05:34 PM
garys 68's Avatar
Here's mine for a sanden compressor, I can send a template.
Old Aug 20, 2010 | 11:08 PM
76LQ9TA's Avatar
Here is another version:
Old Aug 20, 2010 | 11:51 PM
Pro-Tour Heavy Chevy's Avatar
PM Sent. The Brackets look awesome.
Old Aug 21, 2010 | 08:27 AM
garys 68's Avatar
Here's a link to the build thread. I'll look for the template on monday.
https://ls1tech.com/forums/conversio...rive-done.html
