fuel issues
Old Jun 8, 2006 | 08:54 AM
2qwik4words's Avatar
Default fuel issues
hey guys putting LS1 in 1992 Camaro RS and want to use existing fuel system with minor tweaking is it possible?Will either be using GM intake or Edelbrock intake with MSD ignition system.If the GM is used what Fires the coil packs?
Old Jun 8, 2006 | 09:11 AM
stealth71's Avatar
Kind of confusing. Are you talking about running an LS1 w/ a carb? You already stated MSD ignition system, that would fire the coil packs. Edlebrock has a kit w/ the ignition box or you can get the box alone. Do a search on here. There are some people running carb setups already.
