Drive-By-Wire Gas Pedal Compatibility
White/black--5 volt reference
Dark blue--Pedal sensor signal 1
Brown--low reference
Tan--5 volt reference
Light blue--Pedal sensor signal 2
Purple--low reference
A TAC I have out of a 2004 pickup has those same wires coming out of the connector on the left as you face the TAC plus:
Yellow/black, Dark green, Gray.
The connector on the right is missing so I don't know what colors are there. Seems like your pedal should work if you can figure out the three extra wires, assuming your TAC is same as the one I have.
