Wiring up a chevy keyed ignition, help
Old Jun 19, 2006 | 08:14 PM
jimmyp's Avatar
Default Wiring up a chevy keyed ignition, help
So ive got a ignition switch from an impala. I need to know what wire to hook up to the battery, ground and the starter. Any info is appreciated! Should be similar to most ignitions.
thanks
Old Jun 19, 2006 | 10:00 PM
digitalsolo's Avatar
www.the12volt.com has ignition wiring color codes for most years/makes/models of cars. Just search in the remote start area.
Old Jun 29, 2006 | 05:40 PM
jimmyp's Avatar
ok ive located what does what, thanks
edit: never mind...I need a relay inline now. where can I find one?
thanks!
Old Jun 29, 2006 | 10:51 PM
G-Body's Avatar
sawzall wielding director
A relay inline for what?? If you are looking for just a standard 30A automotive relay check the junkyards, lots of 80`s-90`s GM`s use a single relay in a holder with a fuse for the fuel pump. It is usually mounted on the drivers side strut tower.
Edit: I meant to say lots of 80`s -90`s FWD GM`s check for midsize cars first I think most all of them use that setup.
