Last wiring question (hopefully)
Old Jun 21, 2006 | 12:53 AM
RWDCelicadude's Avatar
Default Last wiring question (hopefully)
Okay, I'm putting the harness into the car and I realize there are a couple wires I still don't know about. I have pin 23 on the blue connector that says it's a low reference but when I got the harness it was cut off. Do I need this to go to anything? Also I assume I need to hook a resistor into the fuel tank pressure sensor wires to make it think everything is good. I have the two wires marked out of either pcm connector but I need to know what value resistor to put between them. Any and all help is appreciated.
Darin
Old Jun 21, 2006 | 12:51 PM
G-Body's Avatar
sawzall wielding director
The pinouts that I have from a 99 f-body say that 23 blue is a grey wire and is the low reference (ground) for the fuel tank pressure sensor. What year is your harness? As far as eliminating the fuel tank pressure sensor I just had it deleted in the computer, mabey someone else has used a resistor and can chime in.
Old Jun 22, 2006 | 02:04 AM
I actually just tracked down a diagram, it's for an LS7 but all the pins and wire colors match so I think I can go from there. Although, if I can turn it off I'll just do that and get rid of all the wires, that would make things much nicer. Thanks for the reply.
