Chevelle Update.
Old May 18, 2006 | 06:10 PM
ls1_chevelle's Avatar
Default Chevelle Update.
ITS ALIVE MUAHAHHAHAH. I've waited for this day for like 2 years. Gotta get more tranny fluid, coolant, and finish the fan mount then I'm good for a bit(if theres no leaks) haha.
Thanks for looking!
-Matt
Old May 18, 2006 | 06:13 PM
rotoober's Avatar
Congrats! I hope mine will be drivable by the end of August, and I'm just getting started. 2 years, you must be stoked!
Old May 18, 2006 | 06:43 PM
LSxChevelle's Avatar
Congrats!! I'm jealous as mine is a bare frame right now...
Old May 18, 2006 | 06:57 PM
bczee's Avatar
damn.. beat me 2 it.... Good going dude !
Old May 19, 2006 | 09:33 AM
stealth71's Avatar
Wow are these all Chevelles in progress. Good to see everyone moving along. What motor mounts did you end up using? What were the complications associated with them?
Good Work. We need some pics.
Mike
Old May 19, 2006 | 09:34 AM
stealth71's Avatar
What is done to your suspension? What are the wheel and tire specs? I like your stance.
Old May 19, 2006 | 10:50 AM
Stu Cool's Avatar
Hey, Congrats and way to go! I know how anxious you have been. Just wait till get it out and drive it. Your grin will be permanently implanted! How about some pictures?
Pat
Old May 19, 2006 | 02:14 PM
67RSCamaroVette's Avatar
congrats matt! now post some pics/vid!
Old May 19, 2006 | 02:33 PM
diognes56's Avatar
Congrats . I am jealous.
David
Old May 19, 2006 | 03:51 PM
I used the BRP mounts... Because I have the 6.0l I had to notch the firewall a bit to clear the back of it. With the 4l80e I have no tunnel in the car. People that do not mod the tranny tunnel have one low hanging 4l80e which I do not like. I'm gonna build a tranny tunnel myself. Aside from that, small hickups like my Tanks Inc kit hitting the trunk floor(cutting it out and making access panel).
Suspension wise... Afco spring adjusters 9inch free height springs, in the back they are 12 inch free height, single pig tail. Its pretty simple right now. Gotta get it on the road yet!
Thanks for the comments, I'll try and get some crappy footage tonight and some alright pictures
-Matt
Old May 19, 2006 | 04:25 PM
stealth71's Avatar
Looks good. I've been planning on ordering those springs and adjusters. What pound springs are they? 750 front/ 150 rear? Looks good I will be doing some tunnel surgery for my T56.
Whell and tire specs please?
Any other necessary mods w/ BMP mounts? Notched pan, CTS pan ... Which pan are you running?
Thanks - Trying to get this straightened out because the motor will see it's first test fit this weekend.
Old May 19, 2006 | 04:33 PM
650 fronts 175 rears. (I'm gonna step up to 850/225 or 950/250 once I get more suspension work done)
Wheels/Tires 16x8 GM ZQ8 S-10 wheels. 255/50/16 rubber. Kumho 712's.
Oil pan.... Camaro oil pan with no mods. Thats how far the BRP mounts set it back. You put them on the engine, lower the engine in place get it straight and all that good stuff, tack the clam shells to the frame, pull engine out leaving clam shells there. Drill new holes and put your hardware in.
-Matt
Old May 19, 2006 | 08:18 PM
John B's Avatar
Moderator
Congrats! Any pic's for us?
Old May 19, 2006 | 11:52 PM
stealth71's Avatar
Thanks that solves my mount problem. Wow this forum rocks. I'll get some pics of my project up this weekend.
What are your suspension plans?
I'm stock front. Rear: SSM lift bars lower, BMR adjustable uppers, Wolfe Spherical bushings and a passenger side bag. Will be doing sprins soon. The LS1 will make the front ride high.
Old May 21, 2006 | 09:57 PM
I'll try and get some better ones up soon!
here is a short clip of computer number one... This one idles waaay rough for some reason. Computer 2 idles perfect... LS1tech.video or whatever won't let me upload it right now for some reason.
http://video.ls1tech.com/video/ACBD9...55A75FB8F0.htm
-Matt
Old May 21, 2006 | 10:03 PM
stealth71's Avatar
What kind of exhaust are you running? Sounds good.
Old May 21, 2006 | 10:08 PM
Hooker Super Comp LT's
-Matt
Old May 22, 2006 | 06:13 PM
stealth71's Avatar
Did you make your BRP adapter plates or buy the kit from them? Do you have an A/C box on the pass side?
Put up some pics when you get a chance so we can see what you have done.
Old May 22, 2006 | 06:28 PM
The mounts are BRP but I did not buy direct. A guy on here bought the kit and decided to go with a aluminum big block so I bought them for a killer deal. No A/C... Never did check to see if it would clear.
I'm pretty busy but I'll find time for pics.
-Matt
Old May 22, 2006 | 08:08 PM
stealth71's Avatar
Thanks. I'm not going to run A/C for now anyway. I'll wait till I can afford an under dash unit. Until then I won't mind sweating while hauling ***.
