grounds at the top of the harness
Old Jun 24, 2006 | 08:03 PM
Blackdog76's Avatar
Default grounds at the top of the harness
I am installing a 6.0L harness and have everything plugged in and grouned except 2 ground attatchments that come out of the harness at the top of the engine are near the back. Any help as to where these go would be much apriciated. I'm assuming they go on the engine somewhere but I looked at my friends silverado for reference and don't see where they're suposed to go.
Old Jun 25, 2006 | 12:39 PM
ramair21's Avatar
I would just ground the wires to the heads... There should be some bolts holes. GROUND IS COMMON.. Good luck
Old Jun 25, 2006 | 04:25 PM
Blackdog76's Avatar
Thanks! Thats where I thought they went but just wanted to make sure. I know proper grounding is one of the most important things with a swap. I learned that the hard way with an LT1 swap a few years back.
