converting brakes 1st gen ?
The third en booster needs a new bracket or modify the existing to fit properly on th efirst gen.
Jan
The 3rd gen has different boltpattern to the firewall than the 1st gen, just make it fit and it will work.
Jan
tomorrow im doing a trans filter/fluid change. that will give me money to go brake shopping and she wont know.....
Jan
i drilled out the studs and popped it on.. its a tight squeeze but it fits.
olly
If you do a reaserch @ Team Camaro site you will learn what it does to the geometry but it is up to you and I respect that. You could have the lowering effect with shorter springs or short spring/spring adjusters combination together and have the ability of lowering or raising the front.
I used the 4th gen calipers and rotors all the way around the car and made my own brackets all my templates are in my photo album if you want to use them.
fred
If I can help let me know.
fred
ps
before you get to far be sure you check to make sure your hood will close
also i really like th welding a bracket idea. its easy and will fit right as well as be solidly mounted. thanks guys.
