Oil Pan Measurements
Old Jun 29, 2006 | 08:41 AM
ot04192's Avatar
Default Oil Pan Measurements
Hey everyone
I have a 1955 2dr hrd top putting a 1998 Ls1 with a 4L60. Does anyone know where I can get the specs on the Oil pan and pick up tube changes that are needed for this conversion.
Thanks
Carnut
Old Jun 29, 2006 | 09:11 AM
Wardrum's Avatar
Street & Performance (479-394-5711) sells modified LS pans and pick-up tubes for use with stock '55 frames. If you are going to modify your pan and tube yourself, you can probably get info from their tech dept.
I have purchased several items from them for my LS7 swap....a little pricey but everything worked great and they were very easy to work with.
Old Jun 29, 2006 | 09:49 AM
stealth71's Avatar
Look in the LS1 swap FAQ at the top. Lots of pan info in there.
Old Jul 1, 2006 | 08:12 AM
mramay's Avatar
Originally Posted by ot04192
Hey everyone
Thanks
Carnut
Here's some basic dimensions. I have a GTO oil pan (front sump) if you need dimensions / photos for it as well.
Attached Thumbnails Oil Pan Measurements-ls1measurements3.jpg   Oil Pan Measurements-ls1measurementsfront2.jpg
Old Jul 1, 2006 | 02:09 PM
LSxChevelle's Avatar
Great pics w/ dimensions!
