what can cause injectors not to fire?
Old Jun 30, 2006 | 11:43 PM
91sbcamaro's Avatar
Default what can cause injectors not to fire?
I cant get my injectors to fire, ive been trying and troubleshooting alot of diffrent things.
I got good injectors,
Fuel pump is working(checking pressure when i get my guage on),
Car cranks,
got spark,
Car started for a brief second with starter fluid,
VATS is taking care of,
What else should i check, and what all needs to be connected to get the engine started.
Old Jun 30, 2006 | 11:53 PM
99c5vert's Avatar
are you getting +12 to the injectors? You should have a constant +12 on one side, and the computer would ground the other side to fire the injector. If you have spark, your PCM is probably reading RPM, so I'd start on the +12 side.
Old Jul 1, 2006 | 12:00 AM
91sbcamaro's Avatar
So just take a multimeter and probe the pink wire, and then probe a ground source and it should be 12 volts correct?
Old Jul 1, 2006 | 12:06 AM
99c5vert's Avatar
right. with the ign on.
Old Jul 1, 2006 | 12:11 AM
91sbcamaro's Avatar
Just checked again and they are in fact getting a 12V reading. Whats the next step to diagnose?
Old Jul 1, 2006 | 12:22 AM
99c5vert's Avatar
i'm not asleep... thinking
Old Jul 1, 2006 | 12:33 AM
99c5vert's Avatar
OK. looking at diagnostic steps for a no-start condition... here are a few things to try...
some of the things you have checked already (fuel pressure, +12 to injectors)
Do you have any trouble codes?
a couple of other things:
1- it indicates a bad mass air flow sensor may cause a no start condition - to test, disconnect MAF. PCM will default to speed density.
2- turn ign. off. disconnect crank shaft pos sensor, turn ign on, check voltage. does it have 12V? do the same with camshaft position sensor.
2- possible faulty crank or cam position sensors.
Old Jul 1, 2006 | 11:26 AM
70 LS1's Avatar
Conversion master
How did you take care of VATS?
Old Jul 1, 2006 | 02:50 PM
ricardo colon's Avatar
will a bad MAF cause a RPM drop,( ex. reach 3500rom and then drops)
Old Jul 1, 2006 | 06:15 PM
91sbcamaro's Avatar
I have resistors taking the place of the resistor in the key, and ive been told that the car would start for a few seconds anyway even with a faulty VATS setup.
What do i check the voltage on for the sensors? the wires going to the sensor? just one of the wires to ground or test them together?
Old Jul 1, 2006 | 07:33 PM
crainholio's Avatar
Well dude, last time you posted on this same problem you got advice to handle VATS at the PCM instead of futzing w/ resistors...
Old Jul 1, 2006 | 10:53 PM
99c5vert's Avatar
what i posted regarding the MAF was directly from the service manual for a 99 vette
Old Jul 1, 2006 | 10:54 PM
99c5vert's Avatar
unplug wires from the sensor, put one lead of multimeter to a good ground, use the other to test each wire individually. One of them should be +12.
