What is everyone doing for gauges?
Old Jul 6, 2006 | 05:38 PM
OldSchoolFormula's Avatar
Boone with ultra lites has a camera?
Old Jul 6, 2006 | 08:39 PM
rickbat's Avatar
Stock gauges here...
Converted the tach signal with a (Tachometer Signal Divider).
Converted speedometer with this a manual 4l60e tail shaft.
Old Jul 6, 2006 | 11:10 PM
G-Body's Avatar
sawzall wielding director
Originally Posted by Slo_240sx
They can convert any tach or speed signal to you stock or aftermarket gauges.
What do you mean? Are you talking about with their add on convertors?
The tachometer signal can be changed in the PCM via HPTuners or EFI Live 7 so that it puts out an 8cyl (4 pulse per revolution) signal instead of the factory 4cyl signal. So there is no need for a convertor box for a tach.
The speedometer output from the PCM is a 4000ppm square wave DC signal which is standard on every GM car with an electronic speedo (unless some of the newer cars have started to use serial data for the speedo signal) You can also change the output of this signal as far as how many pulses per mile with EFI Live 7, I don`t know if you can do it with HPTuners too or not. ( mine is set to 2000ppm so that it will work with my oldstyle GM cruise control)
