VSS Sensor
Old Jul 6, 2006 | 04:46 PM
bczee's Avatar
Default VSS Sensor
Does anyone have a T56 VSS Sensor (99 F-Body)?
If you have one sitting around, I need a picture (side and front) of it and dimension of it?
Thanks
Old Jul 6, 2006 | 05:59 PM
Teetoe_Jones's Avatar
The sensor, or the pigtail that plugs into it?
What deminsions do you need?
Tyler
Old Jul 7, 2006 | 12:41 AM
bczee's Avatar
Teetoe..
I need the sensor ... need to see if the F-Body sensor will fit or adapt to a Viper T56.. The Viper one is (about) 11/16" in Dia. and 1 1/4" long (to the inside flange).
thanks
Old Jul 7, 2006 | 12:32 PM
The diameter of the F body VSS is .765" and the length to the flange is 1.331"
Hope that helps some.
Tyler
Old Jul 8, 2006 | 12:14 AM
bczee's Avatar
Teetoe
Thanks, just what I needed to know. I should be able fab or modify the bolt that secures it.
I just measured it.. the Viper VSS is .700" and length is 1.3". Seem if I could trimed/sanded down the body a few hundred's and enlarge the Tailshaft a few hundred's, it should work!?
What do you think ?
