Brake Bleeding Question (HELP PLEASE)
Problem...when the brakes are pumped and held down (wife helping me out), there is no air or brake fluid escaping through the bleeder valve when I open it. I've tried both sides with the same results. I then used a vacuum pump and I was able to get some fluid out but minimal. it seem as if there is no pressure at the calipers.
Question....I have the proportioning valve adjusted all the way to towards the "increase" direction on the rear brakes...I went the other direction all the way to "decrease".... there no change. Logic tells me it should be adjusted all the way to the "increase" seeting to allow more pressure. It seems as if the sytem is blocked but I can still remove fluid with the vaccum pump. Also, the pedal has no resistance at this point after pumping several times.
The front brakes have the same symptoms. No pressure of fluid and air escaping when the bleed valve is released after pumping and holding the brake pedal in the down position. I checked the brake rod and everything seems to be in order in terms of linkage and the booster rod seems to be located in the right position to move the master cylinder piston......anyone got any suggestions for trouble shooting? I'm stumped!
PS..all bleeders are located on top of calipers!
Anyone got any suggestions.
