CTS-V oil pan an alternative to the fbody oil pan?
Hmm. I was checking out the different oil pans available and was wondering if the Caddy CTSV pan will fit the Gbody chasis? The front is about 1/2" thicker than the fbody pan, but the deepest part is further back than the fbody pan even though it angles downward toward the deep section. Could this be used for a gbody? hmm...has anyone tried it?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I am using one on my Chevelle Swap.. search on "CTS-V oil pan" and you should find my post and others along with some pictures.
The CTS-V pan is about 1.25" lower but shorter from front to back which gave me more room around the X-Member.. one problem is that the transition from the front slump to the lower slump many come in contact with the X-Member if you try to drop the engine too low. There are detail in my posts and threads.
Sorry, was in Reno for Hot August Nights. .!
Try this post.
https://ls1tech.com/forums/conversions-swaps/437931-cts-v-oil-pan-accesories-part-numbers-needed.html
Try this post.
Thanks! Hmm.... I wonder how the pan would fit with JohnB's motor mounts in a G-body?
I really haven't seen anybody use this pan in a g-body, curious to know if it would fit.
