Anyone swaping in the D.O.D?
Old Jul 11, 2006 | 04:47 PM
Stampede4ever's Avatar
Default Anyone swaping in the D.O.D?
I'm thinking of doing this swap, just wonder if I'm the only one?
Thanks.
Old Jul 11, 2006 | 05:04 PM
CMcCarthy's Avatar
pardon my apparent ignorance, but WTF is a D.O.D.?
Old Jul 11, 2006 | 05:31 PM
Schitzo's Avatar
Displacement On Demand
I have also been trying to find out if anyone has ventured into that yet. I would really nice to have that feature on a muscle car
Old Jul 11, 2006 | 05:37 PM
Happy Jim's Avatar
Fuel Consumption and Muscle Car in the same sentance -
Old Jul 11, 2006 | 06:09 PM
rocketrider93's Avatar
i would be very careful about something like that. i don't know if it has had enough testing in the real world. i know cadilac tried to do that same thing years ago and it failed miserably. to me there is something wrong with just shutting off fuel to a few cylinders when cruising. i think this would lead to problems later and i would wait for something like that until it is known to be proven and safe. why do the swap only to find out later that you are hurting your very expensive new motor. just my .02
Old Jul 11, 2006 | 06:19 PM
jimmyp's Avatar
its called technology...we have it now, cadillac didnt 30 years ago.
As far as ive researched the DOD stuff is all taken care of in the pcm so it shouldnt be much different than swapping a normal ls1/ls2.
Old Jul 11, 2006 | 06:52 PM
Oscar Will's Avatar
From all the ones I've driven it's pretty seamless but the programming and calibration is REALLY critical. I really think it would be a frustrating venture to say the least but I see no reason why it couldn't be accomplished. Oh....by the way, GM is now calling it "Active Fuel Management"......they dropped the DOD thing.
Old Jul 11, 2006 | 08:08 PM
Schitzo's Avatar
why not? Powerful engine that also gives good gas mileage sounds pretty good to me.
it has been tested and is now in use in some GM trucks. I watched some TV car show where they went into details about how it works. It was actually pretty cool to listen to all that.
Some chrysler hemi 300c and chargers also have this feature.
I know it is just a matter of time before some one integrates this feature into an old car. Just a few years ago, swaping LS1s into old metal might have sounded outrageous and undoable.
Old Jul 11, 2006 | 09:25 PM
Kenova's Avatar
I'll just regurjitate what I've read.
DOD has been around for two or three model years. They don't just shut off the fuel. The valves and coils for the four deactivated cylinders are also deactivated. This way the pistons in the cylinders that are shut down work against what can best be described as an air spring. Any energy used to compress the air is returned to the crank on the down stroke. When the cylinders shut down, the computer changes the amount of throttle opening, hence the use of eletronically controled throttles.
To deactivate the valves a system of solenoids control oil pressure to part of the lifters for the four cylinders. The lifters for the controlled cylinders are different than the other eight, and I'm thinking heavier too. The cam also has different lobe profiles for the controlled cylinders vs the full time cylinders.
If you are willing to run the engine exactly as it was built, it probably wouldn't be that much harder to swap in than any other LSx engine. But as soon as you start messing with it you could have a real headache trying to ballance Throttle opening with activation and deactivation.
Ken
Old Jul 11, 2006 | 09:52 PM
What GM vehicles offer the D.O.D, looking for an alum. block, and rear wheel drive? And does anyone know how much improvement this can make?
Thanks.
Old Jul 11, 2006 | 09:57 PM
chicane's Avatar
I am hoping that Jason from Katech will chime in....
I got an answer from them, while I was there, and there are some performance and durability issue that really dont suit our needs. Hopefully Jason can give the explaination just one more time..... as I cannot remember everything Caleb and Jason explained to me.
Old Jul 11, 2006 | 10:08 PM
00454sscamaro's Avatar
my moms got the 300c dod or w/e its pretty unnoticed... when ya floor it it goes when your cruising ya cant tell if anything happend . but the engine has only got almost 13k on it and was ticking pretty good, till i changed the oil... could be its just a dodge, the crappy mobil 1 that ticks with most ls1's, or a couple more other possibilitys. i say the oil though, because it stopped with the fresh stuff. good luck with all that new fangled electronics.... id rather just go ls1/ls2/ls7 there already good on gas with the right transmission.
