What's everyone using for backup light switch?
Old Jul 14, 2006 | 08:07 PM
67RSCamaroVette's Avatar
Default What's everyone using for backup light switch?
anyone?
Old Jul 14, 2006 | 10:57 PM
pt67camarols1's Avatar
what do you have manuel or auto? If it is manuel there is a pug in tranny for back up light switch.
Old Jul 15, 2006 | 08:10 AM
Scooter70's Avatar
What backup lights?
Old Jul 15, 2006 | 08:37 PM
LS1MCSS's Avatar
You can order the short pigtail to plug into the tranny at RockAuto.com. They are cheap.
Old Jul 15, 2006 | 10:50 PM
ah, ok. where exactly is it located? I downloaded the wiring diagram and didnt see it. Would I probe for +12v there, and run it to a relay for the lights?
Old Jul 15, 2006 | 11:23 PM
gEtyOPaPiOn's Avatar
well in my car (69) i connected the plug on the passanger front side of the t56 ??? IS THAT WHAT YOU HAVE ? LOL if not nevermind haha ....but if you do then i connected them to the pink and green wire i had on my center console ...done!
Old Jul 15, 2006 | 11:53 PM
yessir, i have a T56. i'll look for the connector tomorrow, thanks.
olly
Old Jul 16, 2006 | 12:33 AM
stealth71's Avatar
Here:
Old Jul 16, 2006 | 05:35 PM
LS1MCSS's Avatar
Here is a link for the backup light plug. It plugs into the only place possible on the passenger side of the tranny.
http://198.208.187.182/internet/Part...cpartnbr=PT107
Old Jul 16, 2006 | 08:05 PM
leonpiper69's Avatar
what about us automatic guys???? im useing a b&m pro stick. i assume they make something for the shifter for a reverse light , no?
Old Jul 16, 2006 | 10:55 PM
70 LS1's Avatar
Conversion master
Also it doesn't matter which side is power and which is ground. Its just a switch that shuts when the trans is in reverse. I used the factory wires from my car and connected them to the switch.
If you are not using the factory wiring, then just run 12V to the reverse lights then run the ground from the lights to the trans switch then ground the other side of the switch.
Old Jul 16, 2006 | 11:07 PM
G-Body's Avatar
sawzall wielding director
F-Body or truck trans? Trucks have the backup light switch right on the trans, on f-bodies it is in the dash so you would have to run one on your shifter or change the shifter shaft on the trans and then put a truck switch on the trans.
Old Jul 17, 2006 | 02:43 PM
o1 bird trans, so i guess i'll have to make one. i completely forgot about reverse lights, i wonder what else im forgetting about?????
Old Jul 17, 2006 | 05:09 PM
digitalsolo's Avatar
Heh, I squint hard.
That said for an automatic a momentary lever switch mounted in the shifter works well.
Old Jul 17, 2006 | 08:07 PM
LS1MCSS's Avatar
Summit and a lot of other places sell a B&M universal kit to mount to the shifter for your backup lights.
Old Jul 17, 2006 | 09:28 PM
cool. at least when i get that far i'll no it should be a no brainer....
Old Jul 18, 2006 | 11:52 AM
1st and goal's Avatar
http://store.summitracing.com/partde...5&autoview=sku
For B&M shifters you can use this reverse / neutral safety switch, if you need it for both you will need two switches.
BMM-80629 - $12.95 @ Summit Racing
Marc
Old Jul 18, 2006 | 12:08 PM
sweet, and cheap.
Old Jul 18, 2006 | 01:05 PM
ls67's Avatar
Default b&m switch
All that is is a simple limit switch that you can rob off of an old dryer (it stops the dryer when the door opens) or other electric apliance or purchase at any decent electrical supply store. There are different types normally open and normally closed you can make a reverse light circut work with either. but it would be simple to just put a normally closed one in the groud side of the circut
Old Jul 18, 2006 | 09:29 PM
LS1MCSS's Avatar
Wouldn't you need a normally open, so when it closed it would complete the circuit?
