Hooker engine mounts, no oil pan mod???
Old Jul 16, 2006 | 03:46 PM
1968CamaroSS's Avatar
Default Hooker engine mounts, no oil pan mod???
Getting ready to order engine mounts, from what i've read on the posts, the hooker engine mounts set the engine back far enough so that you dont have to modify the oil pan? is that correct?
Are there any other engine mounts that will have the goal?
Thanks in advance
Old Jul 16, 2006 | 11:27 PM
ls1coupe's Avatar
The two I have done I had to modify the cross member 1/2 inch, using a f-body oil pan.
Old Jul 18, 2006 | 06:14 PM
x-sprint's Avatar
Default Hooker mounts any info
Anyone out there with any info. I earlier mades some mount based on the S & P style. Earlier in the year, I took some quick - rough measurements with a Unisteer conversion mockup and it appears to need another 1 1/8 " - 1 1/4" setback to clear the stock oil pan. A post in the swap sticky says the Hooker mounts have a 1 3/16" setback from the S&P mounts. This should put us in the ballpark. Recent surgery pevents me from taking more exact measurements.
Old Jul 18, 2006 | 11:22 PM
pt67camarols1's Avatar
If you use hooker adapters make sure you done with your gas pedal swap. I have S&P adapters and it is a bitch to reach to gas pedal mounting spot and some of the sensor in the back.
