Knocking coming from water pump. Please Help!
After doing some searching, I found out about piston slap, but my car has the knock at all times, not just during warm up. I can hear the knock slightly at idle and with higher RPM it goes away and then comes back louder around 3000 or so. I made a stehoscope with some tube and a piece of steel. I don't hear any knocking on the heads, block or exhaust ports. I do hear it on the water pump housing. Suspecting the water pump, I took off the pulley and I still hear it! What would cause noise throught the water pump that is not the water pump? What should I do to figure out what is wrong?
thanks,
Tom
