Need Help on sensor location
Old Jul 18, 2006 | 11:03 AM
jess williams's Avatar
Default Need Help on sensor location
The engine I am working on is a 5.3 truck engine. I bought the engine with the intake removed and there are a few things I need to know. I hope someone here can help me out.
There is a boss on top of the intake that looks like a plug was there and I need to know if it was a plug or a sensor. It is on the top front area right behind the Tbody. I hope it was a plug because there is a hole there. I can repair it if it was just a plug, but, I will need a new intake if it was a sensor.
There is another place on the rear of the intake aiming toward the firewall where there is another sensor that is broken off inside the intake. It does not seem to have threads. It looks like it just pushes into the intake. What sensor is this?
Thanks for your time....
Jess
Old Jul 18, 2006 | 11:23 AM
bczee's Avatar
Not sure what a 5.3 Truck enine look like up close, I have a LS1 F-Body. It sounds like the front one is the EGR port. The rear one could be the MAP/Vacumn ports and the MAP does push in, but there should be latch to secure it.
If you don't get other reply's, try posting a picture.
Old Jul 18, 2006 | 11:42 AM
68shortstep's Avatar
front one (if on top) was for the EVAP
and the rear one is the MAP senser, and yes it just puhes in and out.
Old Jul 20, 2006 | 06:45 AM
Thanks for the help....
Jess
