LS1 in a '99 S-10 wiring
His name is Jared, He specializes in S-10 swaps. He built my harness and all of my factory guages are 100% functional. He can also set you up with computer programming to make everything work.
Hope that helps.
The S10 gauges for 99 use serial communications, there isn't a dedicated output for each gauge. I expect that there is some level of programming required to make them all work.
Visit CurrentPerformances' website and call Jarred afterward. He can answer your questions. He just did the harness and PCM reprogramming for my truck. Yes, it was fairly expensive (I spent as much on the harness / PCM as I did on the 6.0L truck motor), but its a brand new custom made harness for my application, a reprogrammed PCM (to my specs) and the reprogramming included a Predator handheld)
'JustDreamin'
