2nd gen and 4l80
Old Jul 26, 2006 | 06:51 PM
KHShapiro's Avatar
Default 2nd gen and 4l80
2nd gen guys, is there room there for an lsx & 4l80?
Old Jul 27, 2006 | 12:49 PM
rocketrider93's Avatar
do a search lots of guys are doing or have done the ls1 swap in a second gen. don't know about the 4l80e. do a search for 76ls1bird
Old Jul 27, 2006 | 01:28 PM
KHShapiro's Avatar
Thanks for the advice , but not only had i already done a search, its not the ls1 swap i have a question about its about a 4l80 and the trans tunnel.
I do thank you for trying to push me in the right direction though.
76ls1bird did a lot more than i am willing to do in my project.
I do not have a 4l80 to size up .. soooooooo if anyone out there has already take some measurements / installed or attemped to install one let me know.
Old Jul 27, 2006 | 01:30 PM
KHShapiro's Avatar
i should have made my question a little clearer in the orginal post.
Old Jul 27, 2006 | 02:59 PM
Schitzo's Avatar
It should fit without cutting up your tunnel. I believe the T56 is blockier (if there is such a word) than the 4l80E yet it fits fine. However, from what I have read, the 4L80E is a heavy trans and will need extra reinforcement on the trans Xmember
Old Jul 27, 2006 | 04:11 PM
Novas Forever's Avatar
I would say that if a Turbo 400 would fit (and it does), the 4L80 should.
Old Aug 1, 2006 | 01:25 PM
76LQ9TA's Avatar
I am working on this now. I have a LQ9 engine and a 4l80e transmission. I am trying to figure out the best position to mount the engine and if I can retain the use of the front brackets for the ac, alt. and ps. I think the trans will fit fine. I am planning on using the 400 trans crossmember in my car. The car is a 1978 trans am. I also am going to try the pacesetter headers. I talked to BRP about their kit for this car and didn't like the price or cutting the trans tunnel. I should have the engine and trans installed in a couple of weeks. Send me a message if you want any pictures.
Old Aug 1, 2006 | 10:13 PM
350SS's Avatar
Just a word of advice, one of the problems with getting an LSx/4L80 combo to fit in the car is installation technique. The combination of the two was too big to clear my crossmember and firewall (72 chevelle) trying to angle them into the chassis. But when you install them separately, having the trans in place and dropping the engine straight down, with the exception of having to bang the trans tunnel in a couple of places (very minimal) everything fit fine. Like the other person said, if a th400 fits, and it does, the 4l80 will with minimal problem.
Max
Old Aug 2, 2006 | 07:00 PM
curtg21's Avatar
I would check out NastyZ28.com, look in the "High Tech Retrofits" section.
Old Aug 3, 2006 | 12:47 PM
KHShapiro's Avatar
76LQ9TA i would love to see some picture of what you are doing
KHShapiro@msn.com
thanks
Old Jul 14, 2020 | 03:46 PM
Darrin Anderson's Avatar
Default 4l80e in a 2nd gen
I know this is an old thread, but I am wondering if there has been any updates to the 4l80e being put in the 2nd gen? Any pictures? Problems? I have a '77 T/A with a 550 HP Pontiac 428 and am thinking about going with the 4l80e.
Thanks,
docanderson@bellsouth.net
