Cooling question
Old Jul 29, 2006 | 08:35 PM
chickenman97's Avatar
Default Cooling question
Guys
After reading through several post I realize that the steam line can be plugged into the upper radiator tank. Now for the TB cooling lines. Does there have to be a flow through it? Do you plumb an inlet and outlet from the radiator or what??
Thanks,David
Old Jul 29, 2006 | 09:28 PM
slowpoke96z28's Avatar
are you asking if you have too have coolant going through the TB? if so the answer is no if you live in the 48 states. it can be bypassed.
Old Jul 31, 2006 | 01:47 PM
Novas Forever's Avatar
And not running coolant through the TB you will have better performance when the engine is warmed up.
