Map sensor connector pinout needed
Old Aug 6, 2006 | 03:56 PM
Tri5Nerd's Avatar
Default Map sensor connector pinout needed
I broke the connector and got one from the junkyard, now I want to be sure that I have the connect wires in the correct position, so going from the back of the connector in the plugin position, left to right I have gray. green and black, is this the correct order?
Old Aug 6, 2006 | 04:02 PM
618HAWK's Avatar
Not sure what year application you have but here is what it is for a 2001 T/A
Pin (A)= orn/blk
Pin (B)= Lt Grn
Pin (C)= Gray
Hope this helps
Old Aug 6, 2006 | 04:26 PM
Tri5Nerd's Avatar
[QUOTE=618HAWK]Not sure what year application you have but here is what it is for a 2001 T/A
Pin (A)= orn/blk
Pin (B)= Lt Grn
Pin (C)= Gray
Hope this helps
Is the Gray on the left or right side when the connector is plugged in?
I also have a 2001 Z28 motor.
Thanks
Old Aug 7, 2006 | 09:44 AM
voc1's Avatar
do you get your pin out if not let me know I can get the pin out.
Old Aug 7, 2006 | 09:45 AM
Tri5Nerd's Avatar
Thanks, I got it.
