Fuel pressure
Old Aug 7, 2006 | 09:46 AM
chickenman97's Avatar
Default Fuel pressure
Guys
I am trying to figure out what fuel pump to use for my system. I will be running a bone syock LS1 in a 68 camaro. I would like to use an external in line fuel pump. What kind of pumps are you useing?? How much pressure do I need at the fuel rails??
Thanks,David
Old Aug 7, 2006 | 10:29 AM
ls67's Avatar
Default holley inline
got it at summit racing about 130.00
Old Aug 7, 2006 | 10:45 AM
kingb's Avatar
i got mine at napa P5001 carter electric fuel pump
Old Aug 7, 2006 | 11:43 AM
70 LS1's Avatar
Conversion master
I am using a Walbro GSL392 also called a walbro 340. 255LPH inline pump. Same as the Vortech pump. I got mine new off ebay for about $125.
You need 58PSi at the fuel rail.
Old Aug 7, 2006 | 01:49 PM
Guys
WOW!!! That sure beats the price for those Barry Grant fuel pumps.
Thanks,David
Old Aug 7, 2006 | 03:21 PM
bczee's Avatar
With a stock engine, why would you want to run a Extrenal pump ? most likely your got a lot of over kill for a stock engine, unless your looking to have a Pro Street look on the car !
Seem to be a lot of un-needed nose and you would still have to worry about the staving of the pump and need baffles/slump? If you run a slump on your stock tank.. it might not be highway/law approved and your open for tickets.
But, just asking and putting my 2 cents in.
