Egr
Old Aug 9, 2006 | 02:05 PM
glock73110's Avatar
Default Egr
who makes those egr block off's for ls1
Old Aug 9, 2006 | 03:53 PM
bczee's Avatar
GM Sells one, PN #12558346 (cheap, just blocks it).
As does S&P (cost is high but looks good).
Old Aug 9, 2006 | 04:03 PM
motopsychoz's Avatar
does anyone make the air injection block offs?(ones for the exhaust)
Old Aug 9, 2006 | 05:19 PM
bczee's Avatar
I had my welded up.
But with some steel and OEM gaskets. Using a drill, grinder and a cut off wheel, you should be able to make some. You can make templates off of the plate from the EGR tubes or Ex manifold, you can also just trace it with paper.
I made my Engine plates and Hyd Clutch adapter plate with just those tools.
Old Aug 9, 2006 | 08:40 PM
Dhmoto111's Avatar
Originally Posted by bczee
I had my welded up.
thats what i always do, just trace around the gasket and cut it out
Old Aug 9, 2006 | 10:47 PM
70 LS1's Avatar
Conversion master
What they said. You can easily make your own AIR blockoff plates. You can see the ones I did in the pic.
